- - Dreams
B1 Lancer · : , ... · , · Hummer, () · · : ·
The time now is Sun 21 Jul 2019, 06:29
 Forum index » krile.net - »
LOCK-ON
Moderators: SHMITZA_BG, Stoyan, su27
Page 3 of 87 [1305 Posts]   Goto page: Previous 1, 2, 3, 4, 5, ..., 85, 86, 87 Next
Author Message
King_Rat
PostPosted: Fri 23 Jan 2004, 17:49    Post subject:
Patch 1.01
http://www.sukhoi.ru/forum/showthread.php?s=6167f365bfe113a793c70d728711a6d8&threadid=19666
mostly harmless
Back to top
ICQ Number
AirBus7er
PostPosted: Mon 26 Jan 2004, 21:09    Post subject: ...
na tazi mashina moje i da vurvi kato horata:
Back to top
PostPosted: Mon 26 Jan 2004, 22:01    Post subject:
7500 , - . 16 !!!
- . 5
Back to top
Guest
Guest
PostPosted: Thu 29 Jan 2004, 23:19    Post subject:
Imam vypros otnosno LOMAC i 6te byda blagodaren ako mi otgovorite. Zna4i puskam az igrata, vyrvi gore dolu normalno, no po edno vreme kakto si igraq i kokpita iz4ezva. Ina4e ne zabiva, vyrvi si, samo deto priborite i indikatora na 4elnoto styklo gi nqma. Sy6to i kato prevklu4a na vyn6en izgled smoleta nikakav go nqma Sad Pri enciklopediqta sy6to ima podoben problem. Na samoletite im se vijdat samo kolelata Sad i pri demoto go ima6e sy6tiq problem. i neznam na kakvo se dylji. Nai interesnoto e 4e do edno vreme vsi4ko e naredi posle BUF!
Ma6inata mi e Athlon 1700+ , 384DDR, Gf2MX40064. Draiverite sa Detonator 47... ne6to si ne sum siguren to4no posledno kakvo slagah, OS-a e WinXP PRO SP1 HELP!
Back to top
PostPosted: Fri 30 Jan 2004, 11:56    Post subject:
- - - - , . - , . , Sad
Back to top
Guest
Guest
PostPosted: Sun 01 Feb 2004, 12:57    Post subject:
! Sad 6 ... ? ...
Back to top
HOKUM
PostPosted: Sun 01 Feb 2004, 15:51    Post subject:
Smile
Back to top
ICQ Number
cybermate
PostPosted: Wed 04 Feb 2004, 01:58    Post subject:
http://www.strizhi.ru/cgi-bin/yabb/YaBB.pl?board=multiproject
Very Happy :
http://www.strizhi.ru/cgi-bin/yabb/YaBB.pl?board=pilotsphotoglance
Back to top
cybermate
PostPosted: Mon 16 Feb 2004, 23:53    Post subject:
Eto kakvo namerih , rovichkaiki se iz interneta ! Smile
http://www.mig.km.ru/photovideo/mig-29/index.htm
Back to top
Guest
Guest
PostPosted: Thu 19 Feb 2004, 16:03    Post subject:
Help! imam problem s demoto na lock on PC-to mi e:
cileron 2.4Ghz
ATI radion 9200
256 RAM
OS XP i tapoto demo kato go pusna i vutre kabinata premigva t.e.tu e ima tu e nqma otvun samoleta i toi taka a na gforse 4 vurve6e normalno taka pravi6e samo na nai visok setings ot kakvo moje da e a we cibermate ti igrata na disk ima6 li q ako q ima i ako ima6 zapisva4ka stava li da mi dade6 adresa ti i az da ti ptatq prazen disk da mi zapi6e6 cqlata versiq 4e moqta e precakana imli nqkoi drug vuvu foruma ako q ima s nego da svar6im rabotataaa
Back to top
Guest
Guest
PostPosted: Sat 21 Feb 2004, 00:55    Post subject:
Kato si s Radeon 9200, svali i si posledniq CATALYST 4.2 ot www.ati.com , svali go i opitai pak ili si svali modificiranite draiveri ot http://www.omegacorner.com az sum sus radeon 9600 i igrata vurvi kato besna, nqma sini ekrani, nqma nishto ! Mnogo e vazhno kak ti e sglobeno PC-to , ako imash nqkakuv konflikt v BIOS-a nqma da stane dalaverkata, ama ti ako ne si naqsno ne ruchkai , da ne precakash neshtata ! Sushto vnimavai sus Omega draiverite, ako ne si naqsno kakvo pravish , ne gi ka4vai, ina4e az sum s tqh i stigam do 105 fps ! Smile)))))
A vutre sum na okolo 38-40 a, nisko dolu kum 25 fps, na Medium/High settings. DirectX 9b e zadulzhitelen !
Za igrata , sorry no nqma kak da ti pomogna (ne sum v BG) no pregledai post-ovete, mislq 4e nqkoi q imashe ! Smile
Back to top
cybermate
PostPosted: Sat 21 Feb 2004, 03:26    Post subject:
abe tozi gore sum az da mu se nevidi i cookies ! Smile
Back to top
Maverick_su27`
Guest
PostPosted: Sat 21 Feb 2004, 20:52    Post subject:
10x cibermate a onq pi4 deto mu stavalo taka kato na mene deto mu iz4ezvali razni raboti taka be6e i pri mene az si go opravih slojih texturite na 32 bita ne na 16 i mi se opravi hora nqkoi ako ima lock on cqla ta versiq ne demo molq da se obadi da mu pratq disk po po6tata da mi go zapi6e 4e nemoga da si go namerq ot nikade imam samo demo ama mi omrazna a su6to i mi nasi4a malko ako sloja ram dali 6te se opravi
Back to top
Guest
Guest
PostPosted: Mon 23 Feb 2004, 17:17    Post subject:
"-----" Smile Smile ... Sad ... , 10 G-Force-a Twisted Evil ... 2 ...
Back to top
cybermate
PostPosted: Wed 25 Feb 2004, 23:42    Post subject: 1.02
Waggs ( , Ubi.com)
Quote:
As promised, here is a list of the majority of v1.02 changes to date (07 Feb). Note that the list below is simply from the first version of the patch we got this week; it is not final and newer versions will add additional changes. Please hold off on "what about XXXX bug?" type questions.
A key point to remember too: A patch is to fix actual bugs, NOT add new features.
- Fixed inability of some joysticks to use cannon trigger correctly.
- Effect of ECM against the F-15C radar has been reduced.
- Added "+" over padlocked target.
- Re-enabled mini-HUD for all aircraft.
- Increased air-to-air missile effectiveness.
- Players can see each other's smoke rockets online.
- Clients now receive air defense unit radar warnings on there RWR now.
- Fixed blue screen bug of water explosions if user has a GF2 card.
- New controller axis:
Trim Pitch
Trim Roll
Trim Rudder
Radar Slew Horizontal
Radar Slew Vertical
MFD Range
TDC Slew Horizontal
TDC Slew Vertical
- Players can now adjust loadouts of wingmen within player's flight.
- Civilian Traffic option now saved correctly.
- Scenes setting option now saved correctly.
- Hidden objects are no longer visible in the F10 or briefing views.
- All sounds become near silent when game is paused now.
- Reduced radar lock range of Russian aircraft to .85 of radar detection range.
- When Russian planes lock a target and the sensor is changed, the lock will be retained (assuming sensor is capable of detecting / tracking target).
- If Russian aircraft loses lock, the other sensor will attempt to continue lock.
- Fixed aircraft velocity and target velocity indicators for Russian HUDs.
- Range bumping on F-15C VSD has been corrected and TDC is reset to center of VSD after a range bump.
- Increased the thickness of the RPI, RTR, and RMIN lines on the F-15C's HUD DLZ.
- Re-made Mach number indication for Su-27/33, MiG-29 and F-15C.
- Disabled ability to re-arm when landing outside an airfield.
- Trim speed has been increased.
- Removed chaff and flares from MiG-25P / RBT.
- Enabled force feedback trim effect.
- Implemented gain parameters for force feedback effects.
- Disabled cockpit stick neutral position displacement emulation for fore feedback when trim is on.
- Enabled cockpit camera control with joystick axis when cockpit mouse view option is off.
- Changed joystick polling algorithm.
- FBP fixed loadouts now correct.
- Restored mouse zoom limits in the cockpit.
- Mouse view option removed from cockpit options and moved to difficulty options.
- The names for all Russian air-to-ground weapons are now visible on the Russian HUDs when in Russian HUD mode.
- Restored object crash in external view.
- Adjusted visibility range of ground object labels.
- Fixed picture of M-818 on AWACS view.
- Fixed bug regarding Betty voice after switching aircraft (Alt-J).
- Invulnerable flag setting is corrected.
- Ground based SAMs now work correctly with enemy ships in the mission.
- Corrected behavior of turbulence (imperial units).
- Corrected training missions.
- Corrected crash from third mission of F-15C campaign.
This covers most of what has been addressed so far in the 1.02 patch. Again, this patch is not done additional items will be added. Please be patient.
-Matt
Matt "Wags" Wagner
Producer / Ubisoft
Back to top
Jump to:
[ Time: 0.0833s ][ Queries: 13 (0.0145s) ][ Debug on ]
Copyright 2006-2012 Air Group 2000 Ltd. All rights reserved. support@airgroup2000.com
