- - Dreams
Aktuelles Datum und Uhrzeit: Fr 03 Jul 2020, 15:36
Alle Zeiten sind UTC + 2
 Forum-Index » krile.net - »
Virgin Galactic
Moderatoren
Neues Thema erffnen   Neue Antwort erstellen Vorheriges Thema anzeigen :: Nchstes Thema anzeigen
Seite 1 von 3 [34 Beitrge]   Gehe zu Seite: 1, 2, 3 Weiter
Autor Nachricht
Anmeldedatum: 01.01.2004
Beitrge: 27539
BeitragVerfasst am: Di 12 Apr 2011, 21:19    Titel:   Virgin Galactic
Nach oben
Beitrge: 27539
BeitragVerfasst am: Di 12 Apr 2011, 21:20    Titel:
Virgin Galactic -. .
, . - WhiteKnightTwo, SpaceShipTwo. " ".
Virgin Galactic 100 250 . .
Virgin - . , . , .
Nach oben
Beitrge: 27539
BeitragVerfasst am: So 01 Mai 2011, 16:14    Titel:
Scaled Composites Ramps Up SS2 Test Rate
Apr 29, 2011
By Guy Norris
LOS ANGELES Scaled Composites marked a dramatic increase in the test rate of Virgin Galactics SpaceShipTwo (SS2) by completing two glide tests over five days, including a 16-min. 7-sec. glide on April 27 that represents the longest flight to date.
The latest flight is the third in succession to increase flight time, the last one on April 22 having extended the glide to 14 min. 31 sec. The back-to-back flights tested minor aerodynamic and control system improvements to the 60-ft.-long, 42-ft.-wingspan vehicle, which is in development for suborbital space tourism and science flights.
The sudden surge in testing follows several weeks of weather-related delays, and has seen release altitudes from the WhiteKnightTwo mothership raised to 51,000 ft. and beyond. The higher altitudes provide more time to continue the flutter envelope expansion that began with the third flight in November 2010.
The flights also evaluated stability and control, and provided pilot training for the Scaled test team. Glide testing is being used to refine the vehicles aerodynamics and low-speed handling qualities. Building on the incremental envelope expansion approach established with SpaceShipOne (SS1), the next test phase will involve higher-speed subsonic flight with a short burst of thrust from the Sierra Nevada-developed RM2 rocket that will power all vehicles. A follow-on flight-test phase, using longer rocket burns, will open up the supersonic, higher-altitude corner of the SS2 flight envelope.
Once cleared, SS2 will move to suborbital flights. A final phase will involve extensive safety-of-flight and system robustness demonstrations for FAA Commercial Space Transportation operational approval.
Ground testing of the RM2 also is accelerating with preparations under way for a further round of hot-fire runs of the engine following a sixth full-scale flight design RM2 test in late March. The run, which was the first since a hot-fire ground test in August 2010, continued evaluation of engine systems, fuel formulation, nozzle, motor structure and valve/injector performance.
Scaled, which has a firm contract with Sierra Nevada for 50 RM2 engines, says the test met all objectives involving duration, igniter performance, oxidizer flow and pressurization systems. It also demonstrated successful collection of data-acquisition system measurements, structural evaluation, and nozzle ablation, as well as fuel regression rate and stability levels.
Nach oben
Beitrge: 27539
BeitragVerfasst am: Do 05 Mai 2011, 21:15    Titel:
Early on Wednesday 4th May 2011, in the skies above Mojave Air and Spaceport CA, SpaceShipTwo, the worlds first commercial spaceship, demonstrated its unique reentry feather configuration for the first time. This test flight, the third in less than two weeks, marks another major milestone on the path to powered test flights and commercial operations.
SpaceShipTwo (SS2), named VSS Enterprise, has now flown solo seven times since its public roll-out in December 2009 and since the completion of its ground and captive -carry test program.
This latest flight saw a 6:43AM (local) runway take off for VSS Enterprise, attached to its WhiteKnightTwo (WK2) carrier aircraft, VMS Eve. At the controls of the of the spaceship were Scaled Composites test pilots Pete Siebold and Clint Nichols whilst Mark Stucky, Brian Maisler and Brandon Inks crewed the purpose built, all composite, twin fuselage WK2.
After a 45 minute climb to the desired altitude of 51,500 feet, SS2 was released cleanly from VMS Eve and established a stable glide profile before deploying, for the first time, its re-entry or feathered configuration by rotating the tail section of the vehicle upwards to a 65 degree angle to the fuselage. It remained in this configuration with the vehicles body at a level pitch for approximately 1 minute and 15 seconds whilst descending, almost vertically, at around 15,500 feet per minute, slowed by the powerful shuttlecock-like drag created by the raised tail section. At around 33,500 feet the pilots reconfigured the spaceship to its normal glide mode and executed a smooth runway touch down, approximately 11 minutes and 5 seconds after its release from VMS Eve.
All objectives for the flight were met and detailed flight data is now being analysed by the engineers at Scaled Composites, designers and builders of Virgin Galactics sub-orbital spacecraft.
George Whitesides, CEO and President of Virgin Galactic, said: This mornings spectacular flight by VSS Enterprise was its third in 12 days, reinforcing the fast turnaround and frequent flight-rate potential of Virgin Galactics new vehicles. We have also shown this morning that the unique feathering re-entry mechanism, probably the single most important safety innovation within the whole system, works perfectly. This is yet another important milestone successfully passed for Virgin Galactic, and brings us ever closer to the start of commercial operations. Credit is due to the whole Scaled team, whose meticulous planning and great skill are changing the course of history.
Pete Siebold, who along with Clint Nichols piloted the spaceship added:
In all test flight programs, after the training, planning and rehearsing, there comes the moment when you have to go up there and fly it for real. This mornings flight was a test pilots dream. The spaceship is a joy to fly and the feathered descent portion added a new, unusual but wonderful dynamic to the ride. The fact that it all went to plan, that there were no surprises and that we brought VSS Enterprise back to Mojave safe and sound is a great testament to the whole team.
Wing Feathering for Re-Entry
Perhaps the most innovative safety feature employed by SpaceshipOne and now SpaceShipTwo is the unique way it returns into the dense atmosphere from the vacuum of space. This part of space flight has always been considered as one of the most technically challenging and dangerous and Burt Rutan was determined to find a failsafe solution which remained true to Scaled Composites philosophy of safety through simplicity. His inspiration for what is known as the feathered re-entry was the humble shuttlecock, which like SpaceShipTwo relies on aerodynamic design and laws of physics to control speed and attitude.
Once out of the atmosphere the entire tail structure of the spaceship can be rotated upwards to about 65º. The feathered configuration allows an automatic control of attitude with the fuselage parallel to the horizon. This creates very high drag as the spacecraft descends through the upper regions of the atmosphere. The feather configuration is also highly stable, effectively giving the pilot a hands-free re-entry capability, something that has not been possible on spacecraft before, without resorting to computer controlled fly-by-wire systems. The combination of high drag and low weight (due to the very light materials used to construct the vehicle) mean that the skin temperature during re-entry stays very low compared to previous manned spacecraft and thermal protection systems such as heat shields or tiles are not needed. During a full sub-orbital spaceflight, at around 70,000ft following re-entry, the feather lowers to its original configuration and the spaceship becomes a glider for the flight back to the spaceport runway.
Nach oben
Ang
Anmeldedatum: 12.01.2010
Beitrge: 855
BeitragVerfasst am: Do 05 Mai 2011, 22:00    Titel: Re: Virgin Galactic
hat Folgendes geschrieben:
! Evil or Very Mad
Nach oben
Beitrge: 27539
BeitragVerfasst am: Do 05 Mai 2011, 22:22    Titel:
Nach oben
Ang
Beitrge: 855
BeitragVerfasst am: Do 05 Mai 2011, 23:20    Titel:
, ! ! ! Evil or Very Mad Evil or Very Mad Evil or Very Mad
Nach oben
Beitrge: 27539
BeitragVerfasst am: Fr 06 Mai 2011, 01:18    Titel:
Nach oben
Ang
Beitrge: 855
BeitragVerfasst am: Fr 06 Mai 2011, 08:25    Titel:
, , ! Twisted Evil
Nach oben
integrall
Anmeldedatum: 16.09.2008
Beitrge: 1772
BeitragVerfasst am: Fr 06 Mai 2011, 10:28    Titel:
Ang . , . ? Smile
Pavonis Mons / /
http://www.spacebg.com
Nach oben
Beitrge: 27539
BeitragVerfasst am: Fr 06 Mai 2011, 18:58    Titel:
Wink , !
Nach oben
Ang
Beitrge: 855
BeitragVerfasst am: Fr 06 Mai 2011, 19:41    Titel:
. Shocked , ? , . , . , .... Evil or Very Mad
Nach oben
integrall
Beitrge: 1772
BeitragVerfasst am: Fr 20 Mai 2011, 14:23    Titel:
Preslav hat Folgendes geschrieben:
Zitat:
1.
1.1. !!!
1.2. - , ., , - .
Nach oben
Beitrge: 27539
BeitragVerfasst am: So 26 Jun 2011, 20:30    Titel:
The private space plane SpaceShipTwo lands after a successful glide test June 21 at Mojave Air and Space Port in California...
Another successful glide of the first SpaceShip Two craft, christened VSS Enterprise, took place June 23, marking the 14th glide flight test of the vessel an 8-minute, 55-second free fall after midair release from its mothership. The test came a week after VSS Enterprise proved it could be flown on back-to-back days....
Nach oben
Beitrge: 27539
BeitragVerfasst am: Mo 27 Jun 2011, 16:37    Titel:
, Virgin, 440 - .
, , - Virgin Galactic, Torontovka.ru.
Nach oben
Beitrge der letzten Zeit anzeigen:   Sortieren nach:
Gehe zu:
Du kannst keine Beitrge in dieses Forum schreiben.
Du kannst auf Beitrge in diesem Forum nicht antworten.
Du kannst deine Beitrge in diesem Forum nicht bearbeiten.
Du kannst deine Beitrge in diesem Forum nicht lschen.
[ Time: 0.0867s ][ Queries: 12 (0.0232s) ][ Debug Ein ]
Copyright 2006-2012 Air Group 2000 Ltd. All rights reserved. support@airgroup2000.com
