В момента е: Нед 12 Юли 2020, 22:43
Crew Exploration Vehicle
Модератори: Елемаг
Страница 2 от 13 [183 Мнения]   Иди на страница: Предишна 1, 2, 3, 4, ..., 11, 12, 13 Следваща
yautja
Регистриран на: 16 Дек 2005
МнениеПуснато на: Пет 13 Яну 2006, 23:53    Заглавие:
Я какво е постнал един от участниците на форума на НК!
Phase 1 Milestones (for reference only) Date
Phase 1 ATP 7/11/05
System Requirements Review (SRR) 4/28/06
Contractor 1 SRR 6/16/06
Contractor 2 SRR 6/23/06
Phase 2 Milestones Date
CEV Phase 2 Contract Award 8/7/06
System Design Review (SDR) 10/13/06
Integrated Baseline Review (IBR) 11/3/06
Preliminary Design Review (PDR) 10/12/07
Critical Design Review (CDR) 1/12/09
CEV Block 1A Design Certification Review (DCR) 2/6/12
CEV Block 1B DCR 6/8/12
Schedule A DD250 Need Date Launch Date
LAS-1 Test Flight (CDR-2 Mo.) 11/13/08
Crew Module 9/5/08
Launch Abort System 9/17/08
LAS-2 Test Flight (CDR+14 Mo.) 2/24/10
Crew Module and Service Module 12/16/09
Launch Abort System 12/28/09
LAS-3 Test Flight (CDR+20 Mo.) 8/13/10
Crew Module and Service Module 6/2/10
Launch Abort System 6/15/10
LAS-4 Test Flight (CDR+40 Mo.) 3/21/12
Crew Module 1/17/12
Launch Abort System 1/26/12
RRF-1 Test Flight 10/3/11
Crew Module and Service Module 4/12/11
Launch Abort System 8/11/11
RRF-2 Test Flight 2/1/12
Crew Module and Service Module 8/5/11
Launch Abort System 12/8/11
RRF-3 Test Flight 5/1/12
Crew Module and Service Module 11/4/11
Launch Abort System 3/12/12
ISS-1 Flight (1A) 9/28/12
Crew Module and Service Module 6/5/12
Launch Abort System 8/8/12
PC-1 Flight (1B) 1/30/13
Crew Module and Service Module 10/9/12
Schedules B and C Launch Date*
ISS-2 Flight (1A) 3/29/13
PC-2 Flight (1B) 5/31/13
ISS-3 Flight (1A) 9/30/13
PC-3 Flight (1B) 11/22/13
PC-4 Flight (1B) 1/31/14
ISS-4 Flight (1A) 3/31/14
PC-5 Flight (1B) 5/30/14
ISS-5 Flight (1A) 9/30/14
PC-6 Flight (1B) 11/21/14
PC-7 Flight (1B) 1/30/15
ISS-6 Flight (1A) 3/31/15
PC-8 Flight (1B) 5/29/15
ISS-7 Flight (1A) 9/30/15
PC-9 Flight (1B) 11/19/15
PC-10 Flight (1B) 1/29/16
ISS-8 Flight (1A) 3/31/16
PC-11 Flight (1B) 5/31/16
ISS-9 Flight (1A) 9/30/16
PC-12 Flight (1B) 11/18/16
Con-1 (Block 2 LRRF-1) 3/31/17
Con-2 (Block 2 LRRF-2) 9/29/17
Con-3 (Block 2) 3/30/18
Con-4 (Block 2) 9/28/18
Con-5 (Block 2) 3/29/19
yautja
МнениеПуснато на: Съб 14 Яну 2006, 16:00    Заглавие:
Няма да крия, че бях изненадан от "solid vs. liquid propulsion sysytem" статистиката за отказите през периода 1963-2004. Изглежда твърдогоривните системи са над три пъти по-надеждни от течногоривните! Мисля си, че решението да се използва твърдогоривния ускорител на совалката (като елемент от CEV) е доста сполучливо решение. Не само се спестяват разход, но и системата е доста по- безопасна (поне ако се водим по статистиката). По- натам в документа има и оценака на риска според това дали ще се използват течногоривни или твърдогоривни ускорители в първата степен. Става ясно, че използването на течногоривни ускорители е в пъти по- рисково!
Предполагам, че причината за голямото превъзходство на "твърдите", по този показател, иде от факта, че течногоривните системи са доста по- сложни като устройстви и има повече механизми, които да се скапят. Разбира се предимствата на "течните" системи са неоспорими- възможност за спиране/пускане на двигателя по няколко пъти и много по- голям диапазон на регулиране на тягата. Въпроса обаче е дали това е нужно за една първа степен? Във връзка с това се зачудих защо ли руснаците предпочетоха "течни" , а не "твърди" ускорители за своята Енергия? Дали заради по-малкото опит, който имат с твърдогоривните системи, или причината е друга (а може би комплексна)? Rolling Eyes
А ето я и въпросната статистика (1963-2004):
Liquid propulsion: attempts- 2 133; failures- 39 (1.83%);
Solid propulsion: attempts- 3 535; failurs- 20 (0.57%);
МнениеПуснато на: Съб 14 Яну 2006, 16:51    Заглавие:
Всъщност твърдогоривните ускорители имат един голям недостатък- не могът да се регулират и веднъж запуснати спирането им е много трудно. Затова и всички системи които се нуждаят от прецизно регулирана тягата за различните участъци на полета са течногоривни двигатели. Трудната регулация прави също така твърдогоривните двигатели много по-неикономични. Затова и решението за течногоривни ускорители за "Енергия" е правилно.
yautja
МнениеПуснато на: Съб 14 Яну 2006, 17:32    Заглавие:
Да, те са малко като кутията на Пандора- отвори ли се става малко напрегнато. Но все пак статистиката сочи, че повредите са доста по малко при по-просто устроените твърдогоривни системи.
До колкото знам това се компенсира от факта, че цената на разработването, тестовете и производството са по-ниски при "твърдите".
Мисълта ми беше, че като първа степен почти повсеместно се ползват "твърди"-явно имат предмство в този етап от полета. Лично мойто мнение е, че руснаците просто се чувстват по-уверени с "течните" системи, а иначе във всички други страни твърдогоривните ускорители са предпочитани. Чел съм (може би някъде из форумите), че поради по-малкия си опит с твърдогоривните системи са решили за Енергия да направят "течни"- при които имат далеч по- голям опит.
Да не забравяме, че "твърдите" ускорители могат да дадат далеч по-голяма тяга! Това и по- голямата им конструктивна простота ги прави предпочитани като ускорители.
МнениеПуснато на: Съб 14 Яну 2006, 18:05    Заглавие:
Това не е вярно! Относителния импулс на твърдите горива е много по нисък. Всъщност той практически не надвишава 3000 м/с. Тоест при една и съща маса течногоривния ще даде по голяма тяга и ще има по голяма товароподемност. Освен това е много трудно да се направят твърдогоривните ускорители многократно използваеми. Тези на совалката се разглобяват за да могът да се заредят със гориво а тези на "Енергия" се зареждат с обикновени шлангове. Затова и подръжката на твърдогоривните ускорители на совалката е много скъпа. Не напразно новите американски ракети-носители "Алас" и "Делта" са с течногоривни ускорители.
yautja
МнениеПуснато на: Съб 14 Яну 2006, 18:47    Заглавие:
Това не е вярно! Относителния импулс на твърдите горива е много по нисък. Всъщност...
Да, прав си- не е вярно, аз се изразих неправилно. Исках да кажа, че поради простотата на тези ускорители, изключително мощен двигател е по-лесно реализируем по тази технология- ускорителите на шатъла са най- мощният реактивен двигател, доколкото знам. А иначе си прав, ето:
Solid fuel rocket motors have a typical specific impulse of 265 lbf·s/lb (2.6 kN·s/kg). This compares to 285 lbf·s/lb (2.8 kN·s/kg) for kerosene/Lox and ~389 lbf·s/lb (3.8 kN·s/kg) for liquid hydrogen/Lox1. For this reason solids are generally used as initial stages in a rocket, with better performing liquid engines reserved for final stages.
...но по-натам четем:
However, the venerable Star line motors manufactured by Thiokol have a long history as the final boost stage for satellites. This is due to their simplicity, compactness and high mass fraction.
...както и:
The ability of solid rockets to remain in storage for long periods, and then reliably launch at a moments notice, makes them the design of choice for military applications.
...което мисля, че особено облекчава инфраструктурата на космодрума (и въобще цената)- често се налага отлагане на старта и т.н. Въобще течното гориво изисква големи и скъпи грижи.
Така е на теория, но доколкото знам при единственото изтрелване на Буран не са били използвани многократни ускорители- за икономия са били без парашут. При изтрелването на "Полюс" нямам представа какво са използвали, но там нещата май нещо не са минали "по вода" Rolling Eyes ? На практика многоразовост трудно се постига (засега само при "твърдите", или бъркам? ) както казах твърде много и сложни механизми могат да се прецакат при течногоривните.
Но все пак ставаше въпрос за CEV, и според мен избора на NASA е възможно най- добрия, ако го оценяваме като сечение на отделни критерии- икономичност, сигурност и др.
МнениеПуснато на: Съб 14 Яну 2006, 19:01    Заглавие:
На "Енергия" ускорителите както и самата ракета не се минали пълния цикъл изпитания и затова е трудно да се съди. Използването на ускорителя на Шатъл е икономически изгодно защото не се налага разработването на нова първа степен и нова наземна структура. Въобще цялата програма на Буш предвижда максимално използване на компоненнтите на совалката което си е правилно в предвид целите на програмата му. Но за съжаление тези цели твърде малки!
МнениеПуснато на: Съб 14 Яну 2006, 19:09    Заглавие:
Ето една американска карикатура по отношение на целите на CEV:
yautja
МнениеПуснато на: Съб 14 Яну 2006, 19:13    Заглавие:
Е как така малки!? Какво имаш впредид?
yautja
МнениеПуснато на: Съб 14 Яну 2006, 19:21    Заглавие:
О, китайците ще са много напред ако през 2025г възможностите им са на нивото на американците през Златния период '69-'72 Wink ! Не искам да подценявам "дръпнатите" (които го е направил не е прокопсал) ама с този темп на полетите- през две-три години по един-двама космонавти (опс, тайконавти) през 2025г. ще са на нивото на руснаци/янки от '80-те. Rolling Eyes
Assess the top-level Crew Exploration Vehicle (CEV) requirements and plans that will enable the CEV to provide crew transport to the International Space Station (ISS) and will accelerate the development of the CEV and crew launch system to reduce the gap between Shuttle retirement and CEV Initial Operational Capability (IOC);
Define the top-level requirements and configurations for crew and cargo launch systems to support the lunar and Mars exploration programs;
Develop a reference exploration architecture concept to support sustained human and robotic lunar exploration operations; and
Identify key technologies required to enable and significantly enhance these reference exploration systems and a reprioritization of near-term and far-term technology investments.
Ето виж ги! Ако бъдем точни CEV не може да обезпечи редовен транспорт към Луната и Марс. Той може само да подържа ограничено число научни мисии. Или казано по друг начин CEV е един вид американски вариант на "Союз" със спускаем апарат за многократно използване.
МнениеПуснато на: Съб 14 Яну 2006, 19:23    Заглавие:
Ако китайците достигнат нивото на СССР от края на 80-те ще стане страшно! Сегашните програми на САЩ и Русия са на по ниско ниво от програмата на Глушко.
yautja
МнениеПуснато на: Съб 14 Яну 2006, 20:04    Заглавие:
Ето виж ги! Ако бъдем точни CEV не може ...
Не е малко! И за една правителствена програма точно такава трябва да бъде- програма минимум. Нека те направят постоянна обитаема база на Луната,нека прокарат пътеката, а след тях ще дойде "частната" космонавтика, която вярвам вече ще се е развила силно. Не е необходима мегаломанска правителствена програма тип "Глушко"- от собствен опит знам, че на маса и чашка се правят дворци и палати, а в действителност и един кокошкарник е трудно да сковеш.
Не забравяй, че правителствените програми зависят от волята на политиците! В този си вид програмата има по-големи шансове да оцелее и да бъде реализирана, особено като се има предвид големите разходи покрай войните в Ирак и Афганистан. Особено е тревожен и факта, че през 2009 най-вероятно САЩ ще имат демократ за президент, а не републиканец. Тези са особено зле настроени към големи военни и космически програми, и предпочитат да отклоняват държавните пари за доста по- безсмислени работи. Така че една програма минимум, ползваща се (поне сега е така) с голяма обществена подкрепа ще оцелее.
Колкото до авангардните разработки и големите амбиции, то те ще станат приоритет на частните предприемачи- времето за това вече почти дойде. Фантазията и уменията на такива като Бърт Рутан, както куража и страста към приключения на готовите да платят по 100 000 $- това е необходимото.А не непостоянната воля на Буш, Муш и подобни. Виж историята на гражданската авиацията и ще се убедиш, че най-значимите, а и повечето, постижения са дело на личната инициатива и предприемаческия дух на хората, не на правителствата. Историята за "опитомяването" на Дивият запад сочи същото. А нещата са доста сходни- отново имаме един Нов Свят пред себе си. Този обаче е безкраен!
МнениеПуснато на: Съб 14 Яну 2006, 20:10    Заглавие:
Като се има в предвид обаче какви са разходите то има много да чакаме частните предпремачи. По вероятно (на което силно се надявам) да започне нова космическа надпревара и нещата да се ускорят и разширят. А програмата на Глушко не само е 100% реалистично и до 1989г практически всички основни компоненте са били създадени и голяма част даже изпитани. Още 5-6 години и днес щяхме да говорим за първия полет до Марс в минало време.
Но за съжаление нещата не се развиха така.
Сега чакам да видя кога ще полети първия CEV. Щото в момента изоства от графика. При това така и не разбрах какви са причините за това изостване.
Орион
Регистриран на: 15 Мар 2004
МнениеПуснато на: Съб 14 Яну 2006, 20:44    Заглавие:
Интересно - напишете повече за Глушко ( украинец?) и за неговата програма...
[ Time: 0.1033s ][ Queries: 13 (0.0119s) ][ Debug on ]
